.PTS file error
ptc-5330204
.PTS file error
when ever i try to open pts file from my desktop to pro e it says no points found in pts file. while i have tried several times, kindly guide me where i'm doing wrong, the following are the points.
23.320
23.311
23.32
23.293
23.264
23.245
23.226
23.187
23.158
23.119
23.0810
23.0411
2312
22.9313
22.8914
22.8315
22.7816
22.7117
22.6518
22.5819
22.520
22.4421
22.3622
22.2723
22.1824
22.0825
21.9926
21.927
21.828
21.6929
21.630
21.4831
21.3632
21.2533
21.1334
2135
20.8736
20.7337
20.638
20.4639
20.3240
20.1641
20.0642
19.8843
19.7344
19.5945
19.4546
19.347
19.1648
19.0149
18.8750
18.7351
18.5852
18.4553
18.3254
18.255
18.1156
18.0957
18.0858
18.0759
18.0560
18.0461
18.0362
18.0263
18.0164
18.0165
1866
1867
1868
1869
1870
1871
1872
1873
1874
1875
1876
1877
1878
1879
1880
1881
1882
1883
1884
1885
1886
1887
1888
1889
1890
1891
1892
1893
1894
1895
1896
1897
1898
1899
18100
18101
18102
18103
18104
18105
18106
18107
18108
18109
18110
18111
18112
18113
18114
18115
18116
18117
18118
18119
18120
18121
18122
18123
18124
18125
18126
18127
18128
18129
18130
18131
18132
18133
18134
18135
18136
18137
18138
18139
18140
18141
18142
18143
18144
18145
18146
18147
18148
18149
18150
18151
18152
18153
18154
18155
18156
18157
18158
18159
18160
18161
18162
18163
18164
18165
18166
18167
18168
18169
18170
18171
18172
18173
18174
18175
18176
18177
18178
18179
18180
18181
18182
18183
18184
18185
18186
18187
18188
18189
18190
18191
18192
18193
18194
18195
18196
18197
18198
18199
18200
18201
18202
18203
18204
18205
18206
18207
18208
18209
18210
18211
18212
18213
18214
18215
18216
18217
18218
18219
18220
18221
18222
18223
18224
18225
18226
18227
18228
18229
18230
18231
18232
18233
18234
18235
18236
18237
18238
18239
18240
18241
18242
18243
18244
18245
18246
18247
18248
18249
18250
18251
18252
18253
18254
18255
18256
18257
18258
18259
18260
18261
18262
18263
18264
18265
18266
18267
18268
18269
18270
18271
18272
18273
18274
18275
18276
18277
18278
18279
18280
18281
18282
18283
18284
18285
18286
18287
18288
18289
18290
18291
18292
18293
18294
18295
18.01296
18.01297
18.01298
18.02299
18.06300
18.13301
18.22302
18.29303
18.38304
18.42305
18.57306
18.67307
18.78308
18.89309
19.02310
19.14311
19.26312
19.4313
19.52314
19.67315
19.8316
19.95317
20.09318
20.23319
20.38320
20.52321
20.67322
20.81323
20.95324
21.08325
21.22326
21.36327
21.49328
21.61329
21.74330
21.84331
21.95332
22.06333
22.18334
22.28335
22.37336
22.46337
22.53338
22.61339
22.67340
22.74341
22.81342
22.87343
22.92344
22.97345
23.01346
23.07347
23.11348
23.14349
23.17350
23.2351
23.23352
23.25353
23.27354
23.28355
23.29356
23.3357
23.31358
23.32359
23.32360
the points are in "R" and "theeta" co-ordinates
You need 3 coordinates for each point. You'll select the meaning of the points by selecting the type of coordinate system. In this case, R, Theta, Z.
