Point at center of curve?
unknown1
Ok, in WF2 where did they put the place point at center of curve? I
found an earlier post but the answer posted did not work. I cannot find
the pulldown option "at center".
Thanks!
Gerald Lanz
Choose "Center" from the hidden drop down menu (I'm not kidding) in the
reference dialog box
I can't find my screen-capture of it at the present time...
-Brian
I have an assembly model where the pulldown simply does not exist, nomatter what I do. Other models, it is there.
M160
Randy Speed
President and CEO
Speed Consulting, LLC
(972) 938-0490 ph (972) 937-2319 fax
www.speedconsulting.com
I'll check. The "hole" is on a slightly curved surface. Does the surface have to be flat?
