Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Attached pic shows why you need a 3rd constraint. The two points have the EXACT same constraints, yet are in two different places... Where is the other definition?
