"Claudio Stammitti" wrote:
Hey David you can add this issue to the already long list of premature exits event report in the topic called: Premature exit (the sum of all fears). There many users have reported similar crash events and some sort of solutions found by them, eventually the only thing in common is that no one has received a successful answer/support from ptc. This premature exit kind of problems usually take too long from ptc to solve them, because they must be able to reproducte and duplicate the event in their Work Station, in order to work for a solution, otherwise the situation is reported as a consequence of external agents (hardware, video card/drivers, mouse, OS, etc). Anyway, have you been able to identuy a common task or event before pro/e exits? a specific sketch operation, zooming, pannig, rotating, inserting shared data, etc?, just trying to run thin the list of possible internal agents.
