Pro/E performance under Windows XP vs Windows 7
gchampoux
7-Bedrock
Has anyone done any performance tests with Pro/E under Windows 7?
We currently use Windows XP and are starting Windows 7 tests.
Today, I ran the OCUS benchmark, and the Windows 7 results are not encouraging.
On identical PC's, the test ran in 3309 seconds under Windows 7 x64, and 2677 seconds under Windows XP x64.
Based upon those assumptions, our engineers will be unproductive (waiting) for an extra 42 hours/year under Windows 7.
That is expensive non-value time.
We might compensate for the lost time with faster PC's, but that has a cost as well.
Has anyone dealt with this issue yet?
Gerry
3 REPLIES 3
We are currently using Windows 7-64 for all of our WF5 workstations.
Our previous systems were Win XP-32, so the jump to 64 bit was welcome.
Other than that, the jump from Win XP to Win 7 has been underwhelming.
Stick to XP if you can, but jump to 64 bit.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
This week we also tested 2 Workstations with Pro/E Wf 4.0 M150 on Win XP x64 and Win 7 x64.
Exactly the same results as you have: Win 7 is about 20% slower than Win XP.
Turning off Aero in Win 7 caused an improvement of about 3%.
Regards, Domenic
Thank you!
Gerry
