Pro/E
ptc-316072
Pro/E
Hi All my question is How can I make rotational cut or involve cut without using Involve option, just use the cut option. Thank you kourosh
Insert -> Advanced -> Neck (Section must be open)
Or use a sweep with a semi-circular or circular trajectory. You realize that the revolve feature does NOT have to go 360deg?
