Pro Engineer 2.0 and Pro Engineer 3
ptc-2116920
How do you open files created by Pro Engineer 3 in Pro Engineer 2 ? Is it even possible?
Loo Monford. What you say that you want to open a pro-wf3 file in wf2 version i would say that it's not possible becuse in pro-e it don't allow you to open any file of higher version(wf3) in lower version(wf2)but if you despertely needed then you can make a IGS file in (WF3)& then open it in wf2 i think it may work. Regards Abhaya
Loo, Check the following link for the free download allowing the backward compatability you are looking for: http://www.ptc.com/products/granite/gcri/index.htm David
I have almost the same question. My school uses V3.0 education edition and if I buy V4.0 education edition would I still be able to open the V4.0 files in the V3.0 machine? The link that David gave only specified V4.0 and V2.0.
