Pro Pipe Line Stock file - weight/Length
barnesalex
Does anyone know the unit of measure pro pipe uses for the weight/length spot in the line stock file. I would like to not use the weight/length spot in the line stock file as we drive weight through a materials file that is not used with pro pipe. Does anyone have suggestions?
0 REPLIES 0
