I believe it is possible to install ProE using the downloaded .zip files without cutting to a set of CDs, but how do you point it at the 2nd, 3rd, etc disks when it expects a CD change?
Thanks in advance,
Chris Glenister
Thermo Fisher Scientific UK
Extract all of the zip files to the same folder on your PC.
When you run the installer, it won't ask for the extra discs.
When extracting discs 2 and on, you'll be prompted about what to do with some duplicate files.
It doesn't matter. Skip or overwrite. They are identical.
Gerry
