ProE and Knowledge Management
pascal.alberti
Hello, I'll to know if it's possible to push informations (on the screen) when you open pro E for th first time of the day (example the morning)??? Best regards
Create a html page with the information you want to publish and set this page as default with the "web_browser_homepage" setting in config.pro.
