We are migrating all pro e cad data to Siemens team center, We are facing issues ,
Any body can help????
regards,
Siva
TeamCenter is a handful. Exactly what kind of help are you looking for?
It is best to have Siemens take you through the conversion. They can deal with issues as they come up.
Migrating PROE CAD data into teamcenter is my problem. I tried to create the instruction file using dry run option, but it showing some error ...
ERROR ( 282.361): Original Exception pfcExceptions::XToolkitCommError
Pro/TOOLKIT error in function ProSessionMdlList, error code -11
J-Link method pfcSession::BaseSession::ListModelsByType
com.ptc.pfc.Implementation.pfcExceptions$XToolkitCommError
at com.ptc.pfc.Implementation.pfcSession$Session.ListModels(Native Metho d)
at com.transcendata.cadpdm.pe.PEAllModelsCollector.execute(PEAllModelsCo llector.java:218)
at com.transcendata.ipemsoaimport.BulkLoader.load(BulkLoader.java:3824)
at com.transcendata.ipemsoaimport.BulkLoader.main(BulkLoader.java:4809)
ERROR ( 282.361): Final Exception com.transcendata.cadpdm.CADException: Error w hile
collecting all models.
at com.transcendata.cadpdm.pe.PEAllModelsCollector.execute(PEAllModelsCo llector.java:291)
ERROR ( 284.614): pfcExceptions::XToolkitCommErro
r Pro/TOOLKIT error in function ProEngineerEnd, error code -11.
J-Link method pfcAsyncConnection::AsyncConnection::End
at com.ptc.pfc.Implementation.pfcAsyncConnection$AsyncConnection.End(Nat ive Method)
at com.transcendata.cadpdm.pe.async.PEAsyncHelper.close(PEAsyncHelper.ja va:357)
at com.transcendata.ipemsoaimport.BulkLoader.endPro(BulkLoader.java:4084 )
at com.transcendata.ipemsoaimport.BulkLoader.main(BulkLoader.java:4834)
C:\Users\4862>
