Radius/Diameter dims
Amcare
How do you create the radius and diameter dims?
For Radius: Select the arc with single left mouse click and then use middel mouse click to place dim. For Diameter: select the arc with double click of left mouse and then use middel mouse click to place dim. where every you need Singh
Amcare
(To:ptc-1769383)
Thanks for the help!
