Recall: removing component from A simplified Rep
jaykm
Malagi, Jayateertha (GE Consumer & Industrial, consultant) would like to
recall the message, "removing component from A simplified Rep".
jaykm
(To:jaykm)
Hi All,
This is fairly simple but I am at a loss to figure out how to do it. There
is a simplified Rep of an assembly in which I need to remove a component
from that Rep.
I used the definition: "Exclude component" but now I am unable to find a
means to remove this component from the rep. I use Pro/E 2001.
Any advise?
Thanks in advance,
Jaya
jaykm
(To:jaykm)
Hi All,
I found one way to do it easily using Model tree-> Columns
add/remove-->Simplified Reps--> Select your rep and edit as needed.
Thanks!
Jaya
