We recently have switched from Product Point to Windchill 10 (nightmare all in itself)
One user's ProE sessions keeps reverting back to the old ProductPoint server within Server Manager. I have started it without any configs, use the dm_remember_server set to no and it still remembers the old server EVERY TIME!
All the users open ProE with the same Icon that I have shared off the server and nobody else is having this issue. I have exhausted my knowledge of where this damn Server could be remembered.
We are using Creo/Wildfire 5.0 M080 and I will appreciate any help at all.
Erik
I finally found the culprit.
Buried about 4 folders deep in the users work directory a config.fld file with the old server configs set.
Erik,
try to remove %APPDATA%\PTC directory.
Martin Hanak
