Remove section lines from Cross section
ptc-2793288
Hi friends, I want to know how to remove section lines from Cross Section. Please see image: RED lines to be removed or hidden. Thanks
Hey I think nobody replays because there is no drawing to see! So no red lines too. With friendly greetings Christiaan
WillyC
(To:chris5)
Assuming you're working with an assembly... Bring up cross section modify tool by double-clicking the section view. Toggle through components with NEXT until the one you want to modify highlights. Click ERASE / DONE.
Hi Friends. I am unable to attachment the image to this forum as they said there is ftp error. i dont know how?
there are limited extension that this forum recognize. you may want to check the extension of the file you are uploading.
