Ribbon Color Change
ptc-4797316
Ribbon Color Change
Does anyone know how to change the color of the ribbon in Creo 2.0? Currently it's a white ribbon. I'd like to change it to a darker color so it's easier to look at all day.
Zeke
DHLewis
(To:ptc-4797316)
Not possible in the current release of Creo. That would be a good Idea to submit for voting...
DHLewis
(To:ptc-4797316)
That's what I was afraid of. The white ribbon is hurting my eyes something fierce. Where would I go about submitting this idea to PTC?
http://communities.ptc.com/ideas
My recommendation is to decrease the Gamma value in your graphic properties. This will give you much less bright and softer screen. It's enhancing the shadow effects which I find a lot better when working in 3D.Gamma+setting.jpg
Thanks for passing the gamma idea along. I am currently using it and it's making it a lot easier to look at a white screen all day.
