Right Mouse Button Customization
jmay
In a recent workaround I discovered right mouse button customization and in case people are unaware its a great way to reduce and relocate the info stored in a right mouse button selection.
File...Options...Shortcut Menu is the path. Then you can remove or relocate items as you see fit.
0 REPLIES 0
