SKETCHED Line Thickness
agaribay
3-Newcomer
Is there an option to modify the SKETCHED Line Thickness?
Being color blind, it can be a challenge when working with complicated
parts....Doh!
Thanks in advance!
-Art
ProE Wildfire 2.0
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
4 REPLIES 4
agaribay
3-Newcomer
(To:agaribay)
Is there a way to change the SKETCHED Line Thickness in WF2? It would
be nice if the sketched entities were bolder.
Thanks you.
-Art
lwh
(To:agaribay)
Changing the thickness is only possible for plotting.
You can change the color, though: View > Display Settings > System Colors and change the Sketch color.
Then save the settings to a file. You can copy the file contents to Your config.pro to load it automatically.
Did you try the "SHADE CLOSED LOOP" option? That helps a bit...
though, my biggest complaint about that is I can't set it to be ON as a
default... Can't set the "HIGHLIGHT OPEN ENDS" or "OVERLAPPING
GEOMETRY" sketcher helps as default on either... grrrrrrrrr...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
Also being color blind, I found that playing with the line colors until you get a good contrast... or you could change the line font -give sketched lines a phantom or abroken font. Have you tried that?
