STL Import
PierrePatenaude
3-Newcomer
STL Import
Hi to all,
I am on Pro E/P 5.0
Is there a way to import and convert an STL file to a solid? Without any expensive extra modules?
I was under the impression that there was a "Granite" mode to do that : does that ring a bell to anyone?
I found a product from SYCODE online but it doesn't work with my Element/Pro 5 version : I guess these guys stopped developping this product after WF 5.
Any help will be greatly appreciated.
Thank you and regards,
Do NOT import STL files, you will get faceted garbage. Get a STEP or (Ugh!) IGES file.
