SUMMARY (2) Jumping/moving dimensions...
DarrinHiebert
As it turns out, I was a little impatient, and sent out my first summary too
quick. Some other things to try. Several also responded that the problem
does appear to be fixed in M160 for those that are experiencing the issue,
which is at least a good thing.
A big big thanks again to all that responded!!!
Several responded to my summary with these comments:
Ok, so I just made a modification to an existing family table. When I opened the drawing, the Dims were all over the place. I can understand if the dims were just of what I changed, but there were other dims unaffected and still they moved/jumped.......hmmmm.
