Files are not backwards compatible for CREO.
You can open earlier versions with later versions, but not the other way around.
Mathieu,
it is not possible.
Martin Hanak
And from CREO 2.0 ??
Using the GCRI tool you can open newer version models from Creo in older versions of CE/Pro or Pro/ENGINEER. This should provide the solution you need:
Mathieu
It was discussed in one of the earlier post http://communities.ptc.com/message/254637#254637
This post may give you some more information about this.
