Save deformed state
ptc-2032585
Save deformed state
Hi all
Does anyone know if it's possible to save the deformed state of a static analysis?
I may be dreaming that I've seen it done...
Alternatively, is it possible to determine the new volume?
Rui
Hello Rui,
I believe you can perform an export of a vrml in the Mechanica results
window. From
there you can import that vrml file into ProE. If I remember correctly it
is just a surface
model.
Hope this helps,
Steve
Stephen Seymour, P.E.
Principal Engineer
Seymour Engineering & Consulting Group, LLC
www.seymourecg.com
Thanks to Steve.
This is exactly what I had seen and was looking for. In reality it's a facet model, less useful than a surface one :(
Rui
On 22.10.
