Scale an existing 2d IGES in X and in Y
ptc-113113
I have some very nice IGES 2d data and I need to apply a scale factor to it. The X scale does not = the Y scale.
Can someone suggest how to do this?
Andrew Amsden
CAD\PDM Administrator
Midmark Corporation
937-526-8770
4 REPLIES 4
CM10
(To:ptc-113113)
If you have AutoCAD, if I remember correctly you can make a block of it, scale it independantly in X or Y, then explode it. I remember having to do that some years ago.
In Reply to Andrew Amsden:
Andrew Amsden
Midmark Corporation
937-526-8770
You can use the warp feature. You should be able to bring the igs into your
model. Go to Insert->Warp. Select your feature , then under References
select your Coordinate, click on Transform, press ctrl+Alt and pick the Jack
(blue cross), then in the option tab you should be able to pick what you
want to scale.
Hope this helps
Tony
CM10
(To:ptc-113113)
Warp works on 2D data?
In Reply to Tony Jager:
want to scale.
Hope this helps
Tony
It will work on 2d data as well. When you bring it into the model, it will
be one feature. Once you get into warp, it will allow you to select the
individual curves, or other data
