I have some very nice IGES 2d data and I need to apply a scale factor to it. The X scale does not = the Y scale.
Can someone suggest how to do this?
Andrew Amsden
CAD\PDM Administrator
Midmark Corporation
937-526-8770
You can use the warp feature. You should be able to bring the igs into your
model. Go to Insert->Warp. Select your feature , then under References
select your Coordinate, click on Transform, press ctrl+Alt and pick the Jack
(blue cross), then in the option tab you should be able to pick what you
want to scale.
Hope this helps
Tony
