Search tool missing "select all"
glanz
Hi all
We have hundreds of models and each has its own layering system. I would
like to correct them and set them all to one common layer system.
I can create a mapkey to delete all layers then use the search tool in
WF2 to find planes, curves, points, csys etc and it works fine. The
problem is lets say I come to the points layer and I have two hundred
points I need to accept.There is no "select all" option to move contents
to the accept box. I have to stop the mapkey and prompt the user to
select everything and move to the right box, then resume. If there was
a way to "select all" from the binoculars tool the mapkey would run
totally automatic 90% of the time. Any workarounds on this out there?
Gerald Lanz
Teledyen Brown Engineering
Huntsville, AL 35807
256-544-0861
0 REPLIES 0
