Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi everyone, i'd like to select group of entities in a sketch by type. For example, could i select all the geometric constraints and only them in a sketch view to erase them all? Thanks for the answers, have a nice day
In sketcher you can use the filter in the dashboard to set: All Dimension Goemetry Constraint This will allow you to select ONLY whatever is set. Just remember to set the filter back to "All" when you're done or you'll be scratching your head and wondering what's wrong.......trust me.....
Hello Fabian. Can't send anything, but its in the bottom toght of your toolbar, between the red rectangle on the left, and the stoplight on the right. Normally, it says "All" in black on a white background. Good luck! F
