I depend on Photoshop elements (or GIMP). It's easy enough to select the edge by color and then fill; plus, unlike even Creo colored edges, I can not only select an edge color at any time, I can select the part/assembly perimeter and shade/fill it with a slightly wider line to emphasize it against the background, similar to the way drawings and illustrations used to add contrast.
x
