Short edges with threads
Wolfman
When modeling threads with the helical sweep, I get "short edge errors" when I run Model Check Regenerate. Is there a way to fix this? Thanks.
1 REPLY 1
Mahesh_Sharma
22-Sapphire I
(To:Wolfman)
Short edge error in ModelCHECK report is an indication that part has edges shorter then specified limit..
You can disable that check by changing the E to N in respective check file. OR change the value of possible short edge in respective constant file.
