I've been running the Single User Performance Tester with Creo Parametric 2.0. I've run the following operations: Register, CreateWS, Download, VerifyFamilyTable, UndoCheckout, Remove, Delete, and Unregister. The output file contains the time each operation started and ended and whether it was a success or a failure. I'm looking for a parser to read the output file and tell the exact amount of time each operation took, as well as whether it was a success or a failure. Could someone point me in the right direction?
Noora
