Sir, I have creo 2.0 in which I am not able to save model in JT format. Can you help me?
Newbie
Re: Sir, I have creo 2.0 in which I am not able to save model in JT format. Can you help me?
  1. your license must contain Interface for JT module (code 263)
  2. you have to check JT interface item during installation
MH
Martin Hanák
Hi Vaibhav,
Did Martin's reply help you with your issue?  Do you have the license file for the JT Interface and did you check the option during install?
Amit
If you don't have the Creo Interface for JT, you can also try CrossManager: It's a converter which can convert Creo native files to JT.
