Sketcher ellispe that's not horizontal/vertical
fred_roy
Hi everyone,
Is there a way to create an ellipse in sketcher mode that is not in the
horizontal/vertical direction?
I'm not sure if that's clear or not... I hope so.
Jean-Frederic Roy, M.Eng
Sr. Mechanical Designer
SPIELO
Phone: 506.878.6460 <-- PLEASE NOTE NEW PHONE NUMBER
Fax: 506.852.7640
CONFIDENTIALITY NOTICE: The contents of this email are confidential
and for the exclusive use of the intended recipient. If you receive this
email in error, please delete it from your system immediately and
notify us either by email, telephone or fax. You should not copy,
forward, or otherwise disclose the content of the email.
6 REPLIES 6
Hi Roy,
As I know, it is not possible, ellipses are basically controlled in X
and Y directions. I had similar case some months back. I tried in
several ways...by trimming them in to halves and rotating them by
required angle. But, ellipses or part of ellipse sections can be rotated
only by multiples of 90 degrees.
The way to handle this case is to create curve equation.
Thanks & Regards,
Jnanesha KS
T 91-80-4119 0900 Ext: 466
F 91-80-41190901
M 994 500 4179
www.quest-global.com
There is another way, but leads to converting ellipse into a spline.
First create an ellipse on a dummy part and extrude it. Then, try to
create another sketch on part in angular position (angle=which you want)
and use "use edge" option and select ellipse. Save the sketch (.sec
file).
Exit the file (no need to save dummy part).
Open the actual file you are working, and after going to sketch mode,
use the existing ".sec" file. I know this is loooooooong route, perhaps
only the way!
Thanks & Regards,
Jnanesha KS
The way to do this is to use a plane at an angel as your sketcher
reference plane. That way you control the hor/ver orientation.
Doug Schaefer
LinkedIn
My understanding is that this is not a mathematically exact ellipse, but you
can get very very very close by creating 4 conic sections
The crucial steps are that the conic sections are 90 degrees to the
centerlines, and entering the relation
Sqrt(2) - 1
(which is approximately = .414)
for the rho value for the arc (that's the dimension that looks like a
radius)
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Roy, another idea:
First create a new datum plane that is at the x* rotation offset from
your current co-ord system, and normal to your desired sketch plane.
Then when creating the ellipse choose this new datum plane as the
left/right/top/bottom reference.
Thanks & Regards,
Jnanesha KS
Can you wait until Wildfire 5.0? 🙂
Cuz' it's in there as a dedicated icon!
[cid:image001.jpg@01C9FB1E.49DE35E0]
Best regards,
Kevin Alexander
Senior Application Engineer - TriStar, Inc.
TEL: 800-800-1714 x3118
CEL: 270-779-9935
www.tristar.com<">http://www.tristar.com>
[cid:image002.gif@01C9FB1E.49DE35E0]
"Excellence is an art won by training and habituation. We are what we repeatedly do. Excellence, then, is not an act but a habit." - Aristotle
View our Recorded Webinars!<">http://www.tristar.com/software/community.asp>
Sign up for upcoming TriStar Webinars!<">http://www.tristar.com/news/events.asp>
Subscribe to our monthly email newsletter!<">http://www.tristar.com/publications/newsletter.asp>
EADS Selects PTC To Become The Single Provider For Its "PHENIX" Enterprise Product Lifecycle Management Solution<">http://ptc.com/appserver/wcms/standards/textsub.jsp?&im_dbkey=74955&icg_dbkey=21>
PTC Lands EADS Deal for Enterprise PLM<">http://www.designnews.com/article/47482-PTC_Lands_EADS_Deal_for_Enterprise_PLM.php>
PTC Resource Center<">http://www.ptc.com/community/index.htm>
PTC Tech Support<">http://www.ptc.com/support/index.htm>
FREE PTC Webcasts
