I'll put my 2¢ in on the topic, if nothing else, to balance the scales a
bit.
😉I HATE Intent Manager, especially in WF3. Granted it does have some
useful features, but overall I find myself fighting it more than plain
sketcher. Now I've been on Pro since rev 9, so I did have plenty of
time to get used to life without IM. I also despise PTC for continually
making certain features only available in IM and not in sketcher.
 - Why would I want some programmer guessing at my intent? I KNOW my
intent and that's what I sketch.
 - Why should I have to purposely poorly sketch (exaggerate your
sketch) to "fool" IM? I sketch what I want it to be not what I don't.
 - I do a lot of surfacing and odd shaped sketches with very few
dimensions (lots of tangencies) and find IM more cumbersome.
What I wish PTC had done is made constraint manager available in plain
sketcher. Then I could apply the constraints I want any time I want.
My latest big peeve is one I posted a month or so ago for WF3, which is
that for existing features, the sketch setup menu is only available when
you have intent manager on. Now if a sketch is unregenerateable (due to
lost references - sound familiar Rui?), you cannot get into it because
regeneration is required to enter IM, and IM is required to enter
sketcher setup! Any user interface person with half a brain can figure
out that they need a button on the dashboard right next to the one for
"SKETCH" that says "SKETCH SETUP".
For Kenneth: You can disable constraints actively in plain sketcher
without having to regenerate. If you pick "constraints" in the menu,
the current set of constraints will show and you can click and disable
the ones you don't want. You do have to click it again to see what new
constraints were created by your disabling others.
Yes IM has some powerful helps, and can be very handy. But I do quite
well without it.
 Jeff
Jeff Sampson Engineering
 >Subject: Sketcher vs Intent manager
>Just RMB when a new constraint highlights, and pro will put a line through
>it and disable it. Very, very handy, and it greatly lessens the grief
>factor. Doesn't work without intent manager.
>Ken Sauter
>Sauter Industrial Design
>3352 Broadway Blvd #414
>Garland, TX 75043
>972-226-1300
>214-292-8732 fax
>214-724-9100 cell
www.sauterindustrialdesign.com
