"Paul Hickman" wrote:
The only way I can think to do this at the moment is to copy and paste your sketch entities and then add relations such as parallel and coincident such as to make your copied enities uniformly offset. I would however ask why you want to do this. If you want to cut or extrude an offset profile, you can just use the 'Thicken Sketch' option in the feature dashboard.
