Does anyone have data on the drill point angle for a broached hex pilot drill? I downloadad the ANSI spec for set screws and it tells me everything except for the drill point angle. I am using set screws for control orifaces. I need to hold a length of the oriface hole length. This hole length is from the flat face of the set screw to the bottom of the drill point for the broached hex drill point..
TIA
