Standard Holes & DOWEL holes
HugoHermans
Is anybody using standard holes for dowel holes ?? Standard holes are
driving by some thread, but dowel holes have no thread involved. How do you
standardize dowel holes ?
Regards, Hugo.
Uncheck "Include thread surface" from the Shape slide-up panel in the Hole
dashboard?
Nicolas Hostein
Mechanical Engineer
BioValve Technologies
1/
This is not possible (WF1) of blind holes. And dowel holes are mostly
blind.
2/
As for threaded holes, dowel holes are drilled upto a certain depth, and
finished upto a depth less then the drilled depth.
3/
Feature Information does not identify the hole as a dowel hole, but as a
special kind of fastener hole.
So, this is not a decent solution.
Regards, Hugo.
"Nicolas Hostein" <-> wrote in message news:71366@model...
> dashboard?
> Nicolas Hostein
> Mechanical Engineer
This is what we do.
Create a threaded hole blind and turn-off the cosmetic thread (In the Shape
Popup, as Nicolas Hostein suggested)
I filed an enhancement request some time ago to allow a drilled hole to be
blind, no resolution yet.
Thank You,
Vaughn McDaniel III
Mechanical Engineer
JR Automation
13365 Tyler
Holland, MI 49424
Ph 616.820.3330
Fx 616.399.4443
