Stretching a Model
ptc-2430630
Stretching a Model
Is there any way I can stretch an portion of a model to make the model longer ? See picture - I want to stretch the length by adding the blue section (same cross section as the adjacent red sections). Thanks guys.
It is very easy to stretch the model. Use the Move Function in Modify 3D / Faces & Rec Features Select the area you want to move with Select (F2) and By VP Frame Set the direction to move, if you click on the corresponding copilot-arrow you can type in the value, otherwise you can move dynamically with the arrow. Best regards WoHo
Perfect ....... ""very easy"" is an understatement. Thank you again, Woho. Kind Regards, John.
