Summary Import ACAD 2000 DWG
jfeix
RE: [draft] Import ACAD 2000 DWGAs I suspected it was an operator error (aka
ID10T error). As all of you suggested the cause was space in the filename,
i.e. in order for ProE to be able to read the file name there cannot be any
spaces in it, duh!
Thanks to all who replied.
Jack
Users-
I know it can be done, because I did it before, but now I cannot open a
native AutoCAD DWG file in Wildfire. The file was created in ACAD 2004, but
is saved as R14, yet when I go to File->Open, nothing shows up except for
the DWG I exported from ProE.
Thanks for all your help.
Jack
Wildfire 2.0 M130
jfeix
(To:jfeix)
As I suspected it was an operator error (aka ID10T error). As all of you
suggested the cause was space in the filename, i.e. in order for ProE to be
able to read the file name there cannot be any spaces in it, duh!
Jack
Users-
Jack
Wildfire 2.0 M130
