Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
What we do here is place them on a rule based layer so that every time one is created it will automatically get place there. Then the user can turn them on or off when they need to.
Dear Ram Das When u want to switch off Geometric planes, You have two options: make a layer named as u wish, then add item to the layer by pressing + symbol, select feature option, in this option select All Of Type, then tick in Datum planes box. Done,Done,Done. Select that layer and switch off, all planes including geom. Planes will also switch off. B.If u want to switch off only geom. Planes then- make a layer named as u wish, then add item to the layer by pressing + symbol, select feature option and all Geom. planes, and switch off the layer. Regards Vivekanand Prasad Sr.Design Engg. SPHINX WORLDBIZ LIMITED A-27C,Sector -16 NOIDA,INDIA
Ram Das <-> wrote: Hi all, Can anyone help me to switch off Geom Tol datums ? If i switch off planes other planes gets switched off, but not the Geom Tol planes. Thanks in advance. Ram --- You are currently subscribed to model. To unsubscribe send a blank e-mail to -. For assistance, email us at - or find other contacts at www.ptcuser.org/org/contacts.html. PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER, Inc. Pro/ENGINEER is a registered trademark of PTC. Message authors are solely responsible for the content of their posts.
