T790 Printer
MichaelDouglas
T790 Printer
I am trying to add a HP Designjet T790 printer to Creo WF5.0 The highest option it has is T755. Any ideas on how to fix this?
7 REPLIES 7
Michael,
use T755 (or another similar plotter available in ProE). I think you will not encounter any problem during plotting.
Martin Hanak
Martin Hanák
bbigelow
(To:MartinHanak)
I used the T755.
The plot comes off fine.....but just one small issue.
After the plot finishes.....it prints off about 18" of blank paper after that.
Any ideas....
Is that a plotter thing or Pro/e thing?
Any help would be appriciated.
I do nothave that issue. I would check your dtl file and see what the paper size is.
How did you plot your file?
Did you create a custom .pcf (plot configuration file)?
Is so can you show me what options you used?
Thanks!
Yes,
I have created custom pcf files for all paper sizes.This Fixespaper issue and centers plot on the paperand other things. If you send me an email i can send you a copy of a file.
Thanks I really appreciate it.
My email is -
Any suggestions for the T790 for WF2??
