Tapered Extrusion
ptc-944906
7-Bedrock
Tapered Extrusion
Just looking for advice on how to make a tapered solid extrusion. Such as an oval shape that tapers down to an oval shape of the same width,but shorter length over say a 4" distance.
Brian
2 REPLIES 2
The blend tool can make this. It's under 'insert' on the top toolbar on WF 3, you can make the ovals what ever shape you want and choose a distance between
Rick
Rick,
Thank you very much. That was exactly what I wanted. Sometimes I just need to be pointed in the right direction.
Thanks again,
Brian
