Tapped Hole Defaults
aprice01
Is it possible to set as a default for tapped holes not to have a countersink? Furthermore, is it possible to set the default hole type to be tapped hole rather than standard hole?
A big complaint I get is that the default tapped hole is placed with a countersink, unless they remember to turn it off.
We are using WF2, M080.
-Andy
0 REPLIES 0
