Text of the sections' notes
gfraulini
Hi all,
I wonder if there are the options to edit automatically the text of the sections' notes within the drw.
I would need a text like the bottom one, instead now I have the top one.
Thanks.
Bye
2 REPLIES 2
Creo provides 2 drawing options related to drawing view notes, only.
view_note std_din
  • removes SECTION from view note text
def_view_text_height height
  • sets text height
MH
Martin Hanák
jzhang-3
(To:gfraulini)
After you edited 1st section note, you select 2nd note and then click Repeat Last Format, or Properties -> Text Style -> Existing Text: Select Text (to select 1st section note)
