how can I make coaxial wire which are made of Central core wire with 5 outer wires (100-twists per inch) see the fig?
We just discussed this recently.
can you define the relation between rope and wires?
What diameter of wire do you want to use? Can it physically to do 100 twists per inch?
dia is 0.0025833333333333" 1x6 (total dia .0155") yes physically 100 twists per inch.
This is as far as I got, I do not have time to continue at the moment.
I was trying to do it with the regular helix.
thank you but we want wrapping following type.
yes, the part I was having trouble with.
ok!
