Twisted Wire
aminhas
Twisted Wire
how can I make coaxial wire which are made of Central core wire with 5 outer wires (100-twists per inch) see the fig?
9 REPLIES 9
Inoram
(To:aminhas)
We just discussed this recently.
http://communities.ptc.com/message/241982#241982
aminhas
(To:Inoram)
Inoram
(To:aminhas)
What diameter of wire do you want to use? Can it physically to do 100 twists per inch?
aminhas
(To:Inoram)
dia is 0.0025833333333333" 1x6 (total dia .0155") yes physically 100 twists per inch.
Inoram
(To:aminhas)
This is as far as I got, I do not have time to continue at the moment.
I was trying to do it with the regular helix.
aminhas
(To:Inoram)
thank you but we want wrapping following type.
Inoram
(To:aminhas)
yes, the part I was having trouble with.
aminhas
(To:Inoram)
ok!
Inoram
(To:aminhas)
I guess it would be like this, if wound tight.
