Two-dimensional into Three-dimensional
bduncan
Who will be two-dimensional into three-dimensional three-dimensional?
Kevin
(To:bduncan)
I don't have access to the commercial version of ProE this week so it will be Monday before I can get a new part file posted. Here are some general directions if you want to try until then.
19 REPLIES 19
Kevin
(To:bduncan)
You can create cross section curves for the top surface and create a boundary blend. Create a cylindrical solid and use the Offset feature and replace surface feature for the feature type.
bduncan
(To:Kevin)
Prt file you can upload for me? I want to learn about, thank you!
Kevin
(To:bduncan)
Do you need a Student version file or a commercial version file?
bduncan
(To:Kevin)
A Student version file. I would like to know the steps in the design. Thanks a lot.
Kevin
(To:bduncan)
Here is the part file created with the student version.
bduncan
(To:Kevin)
Thank you for your help, I can not open your version. I need the commercial version file。
Kevin
(To:bduncan)
bduncan
(To:Kevin)
Thank you for your help, I will follow your steps to practice again.
I would love to see the final product. Can you share it with the community? A screenshot would be awesome!
-Dan
Kevin
(To:bduncan)
Here is a WF3 file for the construction.
bduncan
(To:Kevin)
Thank you! It's beautiful! Do you know a variable cross-section or scanning mixed achieve the same effect?
Kevin
(To:bduncan)
I'm not sure a variable cross section will work but it might. Not sure what you mean by scanning mixed.
Kevin
(To:bduncan)
Here is a model of the feature using a VSS.
bduncan
(To:Kevin)
viewfile.jpgWhat I mean is a Swept Blend Tool.
I think guys, don't forget to solidify for solid model
Kevin
(To:bduncan)
It looks like it could possibly work but looks like you would have to put more work into the construction.
jborg-2
(To:Kevin)
Hi People,
Blue_duncan, I had a go using a different approach from a VSS. Have a look and see if it is what you wanted
Kevin
(To:jborg-2)
This method works also. Here is an assembly showing a comparison between the methods. I changed the dimensions in your model to match what he gave in the original drawing.
bduncan
(To:Kevin)
Thanks a lot. I love this community。
