Underline Text?
JohnMcC
Underline Text?
How do I create a multi line text note with only certain words or lines
underlined?
Like this:
How do I underline just this word
in this single 2 line text note?
I remember having some type of write up about doing this & other types
of special text, but I can't find it.
I appreciate any help.
John
Hi John,
Add numbered curly brackets around any section of the text you want to
format separately:
SINGLE WORD {1:UNDERLINED}
IN TWO-LINE NOTE
Then, in the drawing, you can
1) select the whole note
2) click again to select just the section of interest
3) right-click-menu -> Text Style
Note that the brackets seem to have a habit of deleting themselves if
the note is edited again without changing the format. Also note that we
don't run prehighlighting, so I'm not sure exactly what the clicks are
with it enabled.
HTH!
Jonathan
If my memory is correct you could break up the note with curly brackets...
{1:How do I }{2:underline}{3: just this word}
...and then format its section individually.
Bjarne
"McClelland, John" <->
29-10-2008 16:51
Please respond to
To
cc
Subject
[proecad] - Underline Text?
underlined?
Like this:
I remember having some type of write up about doing this & other types of
John
use the brackets.. as he says: {1:this word is }{2:underlined}
then you can right click on just that word, change the text style and
select underline
Chocolate adds Spice to Your Life.
Terry Johnson
Sr. Technical Specialist
Raytheon
972-344-5689
"Bjarne Frandsen" <->
10/29/2008 11:34 AM
Please respond to
To
cc
Subject
[proecad] - RE: Underline Text?
Bjarne
29-10-2008 16:51
Please respond to
To
cc
Subject
underlined?
Like this:
John
