Using Style and Simplified Rep together
mobleykm
I am trying to view a Simplified Rep with a defined style and I can't get them to work together. When I am in the simplified rep, I can see the styles that were created in the master rep, but if I try to activate them nothing changes on the screen. Also, the button to create new Styles is greyed out so I can't create one directly in the simplified rep. I thought that I had done this same thing with a different model a couple of weeks ago. Am I missing something or should this work? I am on Wildfire 3 M130.
Thanks in advance.
Kelly
I only got one response to my question involving using Combination Display. This works for what I asked, but I missed one point in explaining the problem. I was trying to work in a family table instance. Some of the components in my instance were suppressed in the master rep. Since I was only able to modify the Styles in the master rep, I had to show suppressed items in the model tree and apply the necessary settings to the suppressed models so that they would show up with the appropriate Style when I called it up in the Instance.
Kelly
In Reply to Kelly Mobley:
Thanks in advance.
Kelly
