View field inspections with Manikin extension
DomenicLaritz
Hello everybody,
does anyone of you create view field inspections by using the Manikin extension?
If so, could you share the instructions how to do this?
Best regards, Domenic
2 REPLIES 2
I found an idea, how to perform view field inspections using the BMX extension (page 21): http://www.qucosa.de/fileadmin/data/qucosa/documents/5994/data/Behavioral_Modeling_BMX.pdf
Hi Domenic,
Yes, you can use User-Defined Analysis to make view obscuration. The following video illustrates how to do it
http://communities.ptc.com/docs/DOC-1388
Vincent
