Hello everybody,
does anyone of you create view field inspections by using the Manikin extension?
If so, could you share the instructions how to do this?
Best regards, Domenic
I found an idea, how to perform view field inspections using the BMX extension (page 21): http://www.qucosa.de/fileadmin/data/qucosa/documents/5994/data/Behavioral_Modeling_BMX.pdf
Hi Domenic,
Yes, you can use User-Defined Analysis to make view obscuration. The following video illustrates how to do it
http://communities.ptc.com/docs/DOC-1388
Vincent
