Hi all!
Just started to use WF 5 in earnest and love the new C2 rounds. However... I have NOT been able to add draft to any surfaces that touch a C2 round. If I change the round type to a normal arc, the draft now works fine. (imagine a 5-sided box with a round on each of the interior vertical wall intersections)
Why is this?
O.K., let me clarify a bit. I'm doing a project with the rounds in a skeleton file. Top down design stuff. My skeleton is the master for the ID surfaces. These C2 rounds are surfaces where mulitple parts cross the same surface. Hence my need to have the rounds be in the part file prior to any draft feature.
Any suggestions?
Lar,
As a rule....draft will not work after the round is placed.
Now the issue: True Class A/exterior/ID surface work utilizes "developed" geometry instead of "resultant" geometry. By placing a round (C2 or not) on a flat/non-drafted surface, you are in effect utilizing "resultant" ID methodolgy. You will constantly face the issue of downstream parts not behaving as you require by approaching a master model in this way.
You must
Hi Lar, I think that the other guys are right. Based upon my experience - you've gotta model the draft into the skeleton model. Good Luck!
I would assume that, if I add draft, then the C2 round is no longer C2 at some intersetctions.
I just found it very interesting that I CAN do what I've described if I use a NORMAL round. It's only when I change the round type to C2 that the draft fails.
